Apr 26th, 2024, 7:01am
High Speed Serializer Architecture (Read 1317 times)
analog_design
INDIA
Sep 10th, 2012, 6:42am
I am just confusing with below attached picture. I have some doubt. This is SerDes architecture.
1. Here How 8b/10b and 16b/20b encoded signal is converted into 8:2 multiplexer ?  actually ODD parallel inputs to EVEN parallel outputs
2. Why do we need to generated always ODD and EVEN signal at output of  Serializer ?
If you have any architecture for 8b/10b encoding then, please, suggest me those pipelin topoloy papers.
thank you
Warm Regards
View Profile analog_design   IP Logged
Re: High Speed Serializer Architecture
Reply #1 - Oct 5th, 2012, 3:32am
Hi analog_design,
1. Probably that is a typo, 8:2 multiplexer. Smiley I am not sure because I don't know the details and background for your scheme.
2. It is not necessary to generate ODD and EVEN signal at the output of serialier. A reasonable structure comes from your requirement, like speed, and the availabe process, and so on.
Yawei
carlgrace
Berkeley, CA
Reply #2 - Nov 28th, 2012, 9:11am
ywguo wrote on Oct 5th, 2012, 3:32am:
Hi analog_design,
Yawei
Actually I don't think it is a typo.  The internal diagram of the 8:2 serialzer will be the same as the 2-1 that is explicitly shown in the figure.  Really what it means to say is it is 2 parallel 4:1 serializers where the ODD path is only nibble and the EVEN path is another.
You only need the ODD and EVEN signals if you are going to use a DDR scheme.  Otherwise you only need one data path after the coding block.
Reply #3 - Jan 16th, 2013, 8:41pm
You are running the flip flops at 1/2 the output data rate (they are slower than just simple gates) and then using Muxes to do the last 2:1 combination at the full speed data rate.
