Sep 23rd, 2026, 8:47pm
why doesn't ac signal add up? (Read 8961 times)
dog1
Dec 10th, 2013, 1:54am
Hi:
I am doing AC analysis for a circuit and the current around a node doesn't adds up. the circuit and the phase and magnitude information are attached and listed below. it can be seen that the cos and sin (real and imaginary) part doesn't add up. Does anyone know why is that?
PS: the table below list the magnitude and phase shown in the graph and also the cos=magnitude x cos(phase) and sin of those signals.
     magnitude      phase            cos      sin
port      2.47E-06      14.56            2.39E-06      6.22E-07
Ic      5.46E-06      73.784            1.52E-06      5.24E-06
Ids      9.38E-06      -108.706            -3.01E-06      -8.88E-06
IL      6.56E-15      -75.439            1.65E-15      -6.35E-15
boe
Re: why doesn't ac signal add up?
Reply #1 - Dec 10th, 2013, 2:06am
dog1,
I checked the values for port. They are consistent.
Edited:
Did you check cmin and gmin? At which frequency is this anyway?
- B O E
dog1
Reply #2 - Dec 10th, 2013, 3:44am
Sorry for my ignorance but what is cmin and gmin? I tried to look them up in the cadence help but I don't think there is anything similar to what you means here.
I find something about nonlinearlity. So do you mean that those values takes care of nonlinearlity? I didn't know that. I always thought AC as linear analysis.
By consistence you mean that the table and figure are consistent or that the data follows KCL?
It's 60G
Thanks!
boe
Reply #3 - Dec 10th, 2013, 5:23am
Dog1,
Cmin and Gmin are minimum capacitance and conductance values that are added to all nodes for convergence reasons. You can choose the values in the options form. While you are at it, you should also check the error settings (particularly reltol, vabstol and iabstol).
- B O E
dog1
Reply #4 - Dec 10th, 2013, 5:59am
Yes, I see that gmin is 1e-12, reltol is 1e-3, vabstol and iabstol is 1e-6 and 1e-12 respectively. I didn't really find cmin (in ADE--simulation--options--analog). Do you mean that I shall check all the voltage and current and make sure that they are much larger than vabstol and iabstol?
boe
Reply #5 - Dec 10th, 2013, 7:53am
Dog1,
Re Cmin, I was a bit too fast in answering: you find Cmin under the analysis options (it is used for tran, but not for AC - so it does not apply in your case).
Yes, all relevant voltages and currents should be much larger than v/iabstol - and the errors should be in the range of vabstol/iabstol or the relative tolerance reltol. Also, the leakage through Gmin should be much smaller than the difference you are looking for.
- B O E
boe
Reply #6 - Dec 10th, 2013, 7:58am
Dog1,
The consistency I mentioned previously was meant in terms of table/figure, not in terms of KCL.
Thinking a bit more about it, I suspect you have a parasitic in one of the models. I suggest you add a current probe (iprobe or voltage source w/ VDC=0) in front of each device and check if the current through those are equal to the port currents.
- B O E
dog1
Reply #7 - Dec 11th, 2013, 5:53am
You are right! there is a great difference between the current in the prob and that shown at the port. But I always thought that the current flowing through the parasitic are also included in the port current. So is it not the case or is the difference is only the current flowing through gmin?
Thanks!
PS: sorry for the late reply. the maintenance messed up the model library and everything just recovered today.
« Last Edit: Dec 11th, 2013, 7:19am by dog1 »
boe
Reply #8 - Dec 11th, 2013, 9:55am
Dog1,
you said Gmin is 1e-12, so you'd need 1 MVolt (AC) to get 1 uAmp error current.
So I suppose your models contain some parasitics which are not included in the pin current of your devices.
- B O E
NB: At 60 GHz you need only a small cap to get 1 uAmp...
dog1
Reply #9 - Dec 12th, 2013, 2:07am
Thanks a lot! I don't know that is possible before. A lot to learn:)
boe
Reply #10 - Dec 12th, 2013, 2:23am
Dog1,
the real reason may be a small charge conservation error (which would be equivalent to a small leakage cap)...
- B O E
