Jul 25th, 2024, 8:02am
Can't get right simulation result from transient simulation (Read 3492 times)
Mikay
Dec 05th, 2013, 5:47am
I have a pure LC(inductor-capacitor) tank set up in the Spectre. The initial voltage for the Cap is 1V and the initial current for the ind is 0A. When I do the transient simulation, different accuracy have different results.
1) when the transient accuracy is "consertive" or "liberal", the output finally settle to 0.
2) when the rtansient accuracy is "moderate". the output is sinusoidal wave.
Since the LC tank is lossless, the tank should oscillate and output is sinusodial.
Anybody know how to deal with this?
-Mikay
Mikay
Re: Can't get right  result from transient simulation
Reply #1 - Dec 5th, 2013, 5:48am
The output is attached. Red line is for "moderate" accuracy. Another is for "consertive" accuracy.
Can any explain this?
Frank Wiedmann
Munich, Germany
Re: Can't get right simulation result from transient simulation
Reply #2 - Dec 5th, 2013, 6:27am
Some integration methods used by circuit simulators exhibit numerical damping. See page 24 of http://www.kenkundert.com/docs/bctm98-MSsim.pdf (or Ken's book http://www.designers-guide.org/Books/dg-spice/index.html).
Mikay
Reply #3 - Dec 5th, 2013, 6:57am
Thanks Frank. A lot to learn for me.Frank Wiedmann wrote on Dec 5th, 2013, 6:27am:
danmiso
Reply #4 - Dec 11th, 2013, 11:50pm
By default, the conservative and liberal settings use the gear2only integration method which has the damping property Frank mentioned whereas the moderate setting uses the traponly method.
You can manually specify an integration method in the transient simulation option.
