Jul 25th, 2024, 6:00am
PSS + sampled PAC (Read 2222 times)
aaron_do
PSS + sampled PAC
Dec 04th, 2013, 10:56pm
I am trying to run PSS + sampled PAC on a sample and hold, and I have noticed two problems.
1) I used the "sampled PAC" analysis directly in spectreRF, and it allows me to plot the PAC waveforms for specific time instances. However, when I try to do a parametric sweep of a DC bias (for example), I can no longer plot the waveform at a specific time instance, and the waveform is always averaged over time. How can I get around this?
2) One solution I tried for the above was to use normal (not sampled) PAC analysis, and then add an ideal sample and hold at those nodes I want to analyze (sah_ideal from analogLib). However, when I do this, the PAC node voltage is attenuated by about 80 dB. Does anybody know the reason for this?
thanks,
Aaron
Frank Wiedmann
Munich, Germany
Re: PSS + sampled PAC
Reply #1 - Dec 5th, 2013, 6:41am
I have never tried this combination. This may well be a bug. By looking at the analysis statements in the netlist, you might be able to find out if the bug is likely to be in ADE or in SpectreRF. I suggest that you present your problem at http://www.cadence.com/community/forums/33.aspx and if that does not help, contact Cadence Support.
I am not sure if the sah_ideal from ahdlLib works properly in pac analysis. It has a hidden state (see http://www.designers-guide.org/Analysis/hidden-state.pdf) that is not flagged as an error because the module is marked as an (* instrument_module *).
aaron_do
Reply #2 - Dec 5th, 2013, 4:41pm
Thanks for the help.
Aaron
