aaron_do
Hi baab,
there should be plenty of references around for how to model an inductor. Why did you choose one in Korean?
Anyway the procedure is very straightforward and logical. You just need to first be able to visualize what kind of passive components the structure will have. For example, a long straight line over a grounded substrate can be modeled as a series R+L with capacitors distributed along the R and L. This can be simplified as an R+L with a shunt cap at either end. After you have drawn your model, you need to find the component values. This is quite easy to do if you understand Y and Z parameters. If you want to make your model more complex, you can then start talking about magnetic coupling, and the skin effect etc...
regards, Aaron
