Jul 16th, 2024, 7:11pm
how to add customer model to a device in Cadence (Read 2720 times)
rf_man
May 23rd, 2014, 7:33am
I want to simulate a customer-made device. I've got the model file, but I don't know how to couple the model file to the device. Does anyone can help?
Kind regards,
Re: how to add customer model to a device in Cadence
Reply #1 - May 25th, 2014, 5:16am
RF_Man,
   If it is a standard model. Use a symbol from analogLib in the
schematic, for example, analogLib mos4. Enter your model name
as the model name. Then in the simulator options include the
your file.
rf_man
Reply #2 - May 26th, 2014, 12:24am
Sheldon,
It's not a standard model. How should it be done then?
Reply #3 - May 26th, 2014, 3:33am
RF-man,
  By a standard model, I meant a model supported by the simulator.
If the simulator supports the model, then you need to define the model
and the path to the model parameters. If the simulator does not
support the model, then you will need to create/define the model,
as well as, define the name and the path to the model parameters.
