Thanks sheldon, the netlist can't be generated due to the same error. I just don't know how to fix this error and what the error exactly means. Sometimes the netlist can't be generated because the circuis is not "check and save". This time I'm stuck by this error and can't go on further.
warm regards,
-Mikay
sheldon wrote on May 23rd, 2014, 2:35am:Mikay,
This log file is reporting Skill errors, this implies that ADE
has not been able to generate a netlist. Can you display a
netlist? If not, then you need to fix the errors that are causing
netlisting to fail.
