Jul 24th, 2024, 4:32pm
Writing results to a txt file for MonteCarlo simulation (Read 590 times)
mtp3
Sep 03rd, 2014, 9:13am
Hi!
I am trying to simulate a simple RO using ADE and I use the freq_meter component(written in Verilog A) from the standard cadence library to write the results to a file location specified as "/../period.txt" in the verilogA description.
Now, my question is how do I save the periods.txt file if I am doing a MonteCarlo simulation with 500 runs as the file would be over written for every MC run.
Thanks and regards,
wandola
Re: Writing results to a txt file for MonteCarlo simulation
Reply #1 - Sep 8th, 2014, 6:37pm
my understanding is that for every MC run, the saved text file will be opened for writing and the new data will be appended to the end of the previously saved data. In the end of one MC run, the text save will be saved and closed. This will last untill all MC runs finish.
Actually I also have a followup question regarding this.
If I run MC simulations using multiple cores (parallel), it means the same simulation will run simultanenously. How will the file be written?
thanks.
