An assertion failure indicates a bug in the simulator. If you can, you should send your netlist to Cadence so they can find and eliminate the bug. If you cannot wait for Cadence to fix this, then you should recognize that you are doing something unusual (if it were not unusual, then lots of people would have excited the bug and Cadence would have fixed it by now). So, try eliminating anything you are doing that is unusual. You generally need to employ trial and error to find the one thing that is causing the problem and then finding a way to work around it.
