May 19th, 2024, 11:15am
PSTB analysis in Cadence (Read 3406 times)
Sumit Kumar
IIT Madras
Sep 08th, 2014, 4:51am
I have a circuit with periodic steady state operating point. I am able to get PSS converged. But when PSTB is run, it shows the error message "Assertion failed in file `spIntegrate.c' at line 326"....has anyone encountered such message ? will appreciate any help.
Sumit
raja.cedt
Re: PSTB analysis in Cadence
Reply #1 - Sep 8th, 2014, 7:42am
please give some more details, open the netlist and check that corresponding line.
Raj!
Reply #2 - Sep 8th, 2014, 9:29am
An assertion failure indicates a bug in the simulator. If you can, you should send your netlist to Cadence so they can find and eliminate the bug. If you cannot wait for Cadence to fix this, then you should recognize that you are doing something unusual (if it were not unusual, then lots of people would have excited the bug and Cadence would have fixed it by now). So, try eliminating anything you are doing that is unusual. You generally need to employ trial and error to find the one thing that is causing the problem and then finding a way to work around it.
