Aug 14th, 2024, 9:18pm
root raised cosine filter parameters setting (Read 146 times)
adnan
Feb 13th, 2017, 7:04pm
hi
i tried to use root raised cosine filter in cadence (rflib >> root_raised_cosine) but did not get the proper o/p. Following were the parameters:
alpha
over_samples
group_delay
frame_time
numChipsOut
i tried to apply this filter on 50Gb/s source being used for OOK modulation. can any one guide how to set these parameters correctly.
Re: root raised cosine filter parameters setting
Reply #1 - Feb 14th, 2017, 1:29am
See essentially the same question that was posted yesterday here: https://community.cadence.com/cadence_technology_forums/f/38/t/36905
Andrew
