Hi, I am stuck at one analog circuit problem. So far my friends could not solve it.
This is a gyrator made up of two gm-cells (X1 and Gm2 blocks), transforming CL into active inductor.
equivalent inductance value, Leq = CL / [(gm of X1 circuit block)*(gm of Gm2 circuit block)]
1) Should I simulate the value of overall transconductance of Gm2 circuit block independently or inside the larger circuit with the presence of Cs and CL ?2) Why would V(IN) = Vb ? is it because of
https://www.quora.com/Why-does-an-op-amp-show-virtual-short-during-negative-feed... ?
Note: V(IN) is the gate voltage node of mosfet M6 in Gm2.sch
and X1 is just a CMOS inverter
![](https://i.imgur.com/UczWLV7.png)
Note: The complete gschem schematics and ngspice simulation plots could be obtained from
https://github.com/promach/frequency_trap
