kristin
Vudathu,
In SpectreMDL, available in version 5.0, we have added a binary search capability. While this capability does not allow you to vary more than one parameter, you can set up rather complex goals using the MDL language. I will be happy to send you an example if you wish. As Ken points out, MDL is geared towards cell characterization applications, providing a very powerful native measurement capability. The binary search capability is currently being utilized in a number of applications, such as set up time and dynamic noise margin calculations. But it is general purpose enough to be applied elsewhere. We do not yet support the general scripting aspects of Ocean, such as writing output to arbitrary files, netlisting from the database, etc.
Eugene,
There is a loose ADE (Artist) interface in the IC5.0 version of software. In the Setup -> Simulation Files form, you will see a new field labeled "MDL Control File". You may insert the name of an MDL control file here, and all simulation control and output measurement will be controlled by this file. (The analyses and meeasurements in the ADE simulation interface will be ignored.) Please see the online documentation (cdsDoc) for assistance in setting up a control file.
Kristin
