Jitter Man
Am I? Or am I so sane that u just blew your mind?
Spectre has a conventional small signal analysis, stb, that computes the loop gain. That will work fine if you believe you can turn off the clock while measuring loop gain. Otherwise you will need to use the techniques described in Section 3.4.1 of Kundert's book. Of course, with the clock being active, you will have to substitute SpectreRF's PAC analysis for the AC analysis used in the book.
