Oct 2nd, 2026, 11:41am
Saving difference of two node voltages in Spectre (Read 4437 times)
Lokesh
Jun 18th, 2003, 2:03am
What is the equivalent of the HSPICE command
.print v(vop,von)
(which automatically generates the difference of the two node voltages Vop and Von) in Spectre?
In other words how to save difference of two node voltages in Spectre?
« Last Edit: Jun 18th, 2003, 6:21pm by Lokesh »
Re: Saving difference of two node voltages in Spec
Reply #1 - Jun 24th, 2003, 9:12pm
I don't think this can be done in spectre directly, but since
you can save both components and do the subtraction in
the post processing tools, it's not really needed.
You could of course do it in spectre using a vcvs
between the two inputs, and then outputting the output
of the vcvs (with the output side referred to ground):
diff (vdiff 0 vop vin) vcvs gain=1
Lokesh
Reply #2 - Jun 25th, 2003, 12:47am
Hi Andrew,
Thanks for the helpful comments.
Lokesh
wued
Reply #3 - May 2nd, 2005, 4:52am
you can plot differential value of vop minus von by ADE, then using printvs function to finish it.
