August West
I'll get up and fly away
Listing 1 is not Verilog, it is the analysis portion of a native Spectre netlist.
You should find maxacfreq on the PSS choose analysis form, or the PSS options form.
Concerning altering the source, one does not do this when running PSS & PAC analyses. The pacmag parameter, which is used to specify the source amplitude in the PAC analysis does not affect the source during the PSS analysis. So for PSS & PAC analyses, you can specify pacmag and leave the source unchanged when running the PSS analysis.
The alter statements in Listing 1 is used to turn on one or two tones in the input signal during the QPSS analysis. When running the analysis in Artist, you must manually configure the sources before running the QPSS analysis.
-August
