Jul 20th, 2024, 10:32pm
Start-up check @bandgap reference using spectre (Read 2698 times)
eddy
Mar 25th, 2004, 10:33pm
Hi all;
I'd like to simulate start-up in CMOS BGR(Bandgap reference) using spectre.
Unfortunately, I don't know how to do method for this.
I want to simulate tran. for VDD(0 ~1.8V) and node condtion: 0).
If anybody knows this, let me know.
Thank you.
fastsim
Re: Start-up check @bandgap reference using spectr
Reply #1 - Apr 9th, 2004, 2:39pm
Sweep vdd source from 0 to 1.8.
set IC to '0.0'v on the diode-connected BJTs collector nodes. (assuming you are using vertical PNP in N-Well process.)
If you are using Cadence schematic composer and Analog Design
Environmnet ( Analog Artist), you can set up from from GUI.
Actually, you probably also want to try set vdd to 1.8, but use
IC to set the collector voltages to 0.0v so as to force a false
operating points at the beginning of transient to see if the circuit
will settle to the right solution.
If you ramp you VDD from 0, the transient operating points for all
the nodes should all close to 0. You may not be able to find the
start-up problem while there is a real problem.
