VincentLee
Hello everyone, I have tried to simulate the phase noise(PN) in SpectreRF because of the PSS & Pnoise analysis. However, the PSS analysis can not be convergence well. So I wonder if Hspice can do the same function as PSS & Pnoise in SpectreRF. Firstly, I think the PLL circuit can obtain the steady state after a long time by tran analysis. And then I can save many operating points in a period wave. Just like the PSS analysis in SpectreRF. Secondly, I can use these OP values to do noise analysis. But at this time, a problem occurs: How to consider this? "Active elements with a time-varying bias point can convert noise from one frequency to another, a process known as noise folding, regardless of the origin of the noise." Reference in the manual "Periodic S-parameter and noise analysis using SpectreRF PSP/PNOISE analyses" Who know how to consider the noise folding effect in Hspice? Thanks & Best Regards Vincent Lee
