Jul 16th, 2024, 6:45pm
How to implement ODEs using Verilog-A (Read 3333 times)
shu
Guest
May 17th, 2004, 5:18pm
I am wondering whether I can implement coupled odinary differential equations using Verilog-A and simulated by Spectre?
The equations look like
dx/dt=x*y
dy/dt=x/y
Thanks a lot.
  IP Logged
Re: How to implement ODEs using Verilog-A
Reply #1 - Jul 9th, 2004, 9:13am
Shu -
The equations you wrote could be implemented by two coupled simple circuits, each consisting of a 1-Farad capacitor and a dependent current source. In Spectre, I don't believe you can have a dependent source with a division, so it will have to be Verilog-A.
---- ode.va ----
`include "disciplines.h"
module ode(x,y);
 inout x,y;
 electrical x,y;
 analog begin
   I(x) <+ V(x)*V(y) - ddt(V(x));
   I(y) <+ V(x)/V(y) - ddt(V(y));
---- ode.netlist ----
simulator lang=spectre
ahdl_include "ode.va"
X1 (x y) ode
ic x=1 y=1
tran1 tran stop=1u skipdc=yes
As written, the only DC solutions of your equations are {x=0, y=anything but 0}, and when x=0, the transient analysis is boring.
To get something interesting, I have set "skipdc=yes" and provided initial conditions for both nodes.
-Geoffrey
