Oct 25th, 2026, 10:08pm
Spectre models for MC and Corner sim (Read 1222 times)
Paul
Switzerland
May 26th, 2004, 4:16am
with respect to the discussion about Monte-Carlo simulation (http://www.designers-guide.com/Forum/?board=circuit;action=post;num=1066706959;q...) I have the following problem. Using the syntax suggested by EVI and also presented in the Spectre documentation, I cannot use my models anymore with the corner sim tool.
The workaround I'm trying to implement is the following:
I have a .lib.scs file with the corner info, which calls the .mdl.scs file containing the BSIM transistor models. In the .lib.scs, I create an additional corner called mc which contains the statistics section, all other corners don't contain any statistics part. As the .mdl.scs file contains some calculations (like u0_mis/sqrt(w*l)), I have to keep the inline subckt parts in all corners.
Spectre runs fine with that, but when I use the corner sim, I get the following error:
model `M15.n' (TYP.n.n): parameter `u0': Encountered error which may be         related to a reference to an inherited parameter in a subcircuit, where the subcircuit definition (or any of the ancestor subcircuit definitions) were declared before the parameter being referenced. Ensure that all top-level netlist parameters are declared before any subcircuits are defined.
input.scs says
include "..../mos.lib.scs" section=tt
...circuit definition and analysis description...
TYP altergroup {
include \
   "..../mos.lib.scs" \
   section=tt
FF altergroup {
include \
   section=tt
Any suggestion on this? Thanks for your help,
Paul
Paul
Switzerland
Re: Spectre models for MC and Corner sim
Reply #1 - May 26th, 2004, 4:49am
Sorry guys for bothering you... I gave up searching Sourcelink too quickly. The solution is here:
PCR 274399: Inline subcircuits cannot be used in altergroup
just some line to add to .cdsenv and it works
Paul
Chase Ng
Guest
Reply #2 - Sep 24th, 2005, 9:16pm
Hi, Just want a quick answer, wat to add in .cdsenv?
  IP Logged
Reply #3 - Sep 25th, 2005, 3:38am
spectre.envOpts useAltergroup   boolean nil
chase.ng
penang/malaysia
Reply #4 - Sep 25th, 2005, 6:17am
Thanks... it works!
Chase
Chase
View Profile chase.ng   IP Logged
