Jul 16th, 2024, 1:55am
Problem with verilog vga controller (Read 2773 times)
gekas
Jun 19th, 2004, 7:29am
 Hi, I am a new in HDL synthesis and programming of programmable devices.
Currently I am working on a mouse project and I have problems with my
vga_controller module. Despite the fact that in Modelsim simulation
everything works as needed, when I program a Xilinx 4010XL device, nothing
works as it should. The module that I test is a simple vga controller that
generates 2 pulses h_sync and v_sync so as the display works in 640*400
resolution @60Hz. I also have 6 bits for the colours (rgb). In modelsim
everything works perfect but in the real thing, the screen doesn't receive
any signal or the signals (h_sync and v_sync) are unsynchronized. Below I
provide my Verilog code, so whoever has a bit of free time, please take a
look at it. Note that the design must run at a 25Mhz pixel clock rate. I would appreciate it a lot if you'd help me!!!
//Here is the module. The job that I want this to do is create a totally black screen with a white cursor (32*32 pixels) drawn on the upper left corner of the screen (coordinates (0, 0)).
module vga_controller(clk, reset, h_sync, v_sync, rgb);
input clk, reset;
output h_sync, v_sync;
output [5:0] rgb;
wire [9:0] h_counter; //Counter of pixels in a row
wire [8:0] v_counter; //Counter of rows
//Total pixels in a row are 800 (including back, front porch and visible pixels)
//Total rows in a frame are 449 (including back, front porch and visible rows)
reg h_sync, v_sync;
reg [5:0] rgb;
reg [9:0] x_pos;
reg [8:0] y_pos;
parameter h_counter_start_value = 10'd751;
parameter v_counter_start_value = 9'd413;
parameter zero = 4'b000;
parameter low = 1'b0;
wire [9:0] up_bound_x;
wire [8:0] up_bound_y;
wire row_fin, h_sync_low, v_sync_high;
wire rgb_wire;
//The ports of the below modules are described as this
//counter_X(set (synchronous), reset (asynchronous), clock, data_in, chip_enable, output_count)
counter_10 inst0(h_counter == 10'd800, reset, clk, h_counter_start_value, !reset, h_counter);
counter_9 inst1(v_counter == 9'd449, reset, clk, v_counter_start_value, row_fin, v_counter);
assign row_fin = (h_counter == 10'd751); //End of one line of pixels
assign h_sync_low = (h_counter > 10'd654 & h_counter < 10'd751) ? 1'b0 : 1'b1;
assign v_sync_high = (v_counter > 9'd410 & v_counter < 9'd413) ? 1'b1 : 1'b0;
//Upper bounds of coordinations in the screen
assign up_bound_x = {x_pos[9:5] + 1, x_pos[4:0]};
assign up_bound_y = {y_pos[8:5] + 1, y_pos[4:0]};
assign rgb_wire = (h_counter < up_bound_x & h_counter >= x_pos &
                  v_counter < up_bound_y & v_counter >= y_pos ) ? 1 : 0;  //For the switching between black and white colours
always @(posedge reset or posedge clk)
 if(reset)
 begin
   rgb <= 6'b000000;
   h_sync <= 0;
   v_sync <= 1;
   x_pos <= 0;
   y_pos <= 0;
 else
 begin
   h_sync <= h_sync_low;
   if(row_fin)
     v_sync <= v_sync_high;
   if(rgb_wire)
       rgb <= 6'b111111;
   else
       rgb <= 6'b000000;
