Well, the most sensible option would be to use monte-carlo, and have a parameter with mismatch variation which controls the voltage source. That way you're getting the simulator to do all the random number generation.
If you want to work the long way around, have 90 voltage sources each with a unique design variable name specifying the voltage (or whatever), and then in OCEAN use the desVar() function to assign each of these variables to a random number using the SKILL functions to produce random numbers. All of this could be done in some simple loops. Read the OCEAN documentation for more hints...
