danda821
I need to add a voltage-controlled cap in analog artist. I have check AnanlogLib models, there is only one model which can model voltage-controlled cap, but it can only be used in hspice simulator. I want to use spectre simulator. Do I need to use Verilog-A to model this device? Thank you.
