Jul 21st, 2024, 5:16am
exporting files from spectre to matlab ? (Read 2727 times)
City
Aug 17th, 2004, 1:35am
is it possible to save a transient simulation result and
to export it to matlab for signal processing ? Can
anybody tell me how to do it ?
regards,
City
Eugene
Re: exporting files from spectre to matlab ?
Reply #1 - Aug 17th, 2004, 11:34am
I do this all the time, in both directions. If you have already run the simulation, you can use the waveform calculator's "printvs" command to display the data. You will have to change the format from engineering to scientific units. You then click the "print" command and print to a file. You can only print 1000 or so points this way. For more points, you have to use the command line.
I prefer creating the file with VerilogA. I've included a piece of VerilogA code I use to create files. In Matlab, read the data in with aa=load('IinputCol'); You will have to make sure the path to the directory is in your Matlab path.
`include "constants.h"
`include "discipline.h"
module write1(in);
input in;
electrical in;
parameter real sample_rate = 1e6 from (0:inf];
parameter integer record = 1 from [0:1]; // 1 = record, 0 = don't.
integer fptr;
real period;
analog begin
  @ ( initial_step ) begin
     if (record ==1) begin
        fptr = $fopen("/home/rcvr_5GHz/IinputCol");
     period = 1/sample_rate;
  if (record == 0) period = 1e6;
  @(timer(0, period)) begin
     if(record == 1) $fstrobe(fptr, "%g", V(in));
  @ (final_step) begin
     $fclose(fptr);
