Aug 15th, 2024, 10:13am
Spice3f5 on Linux/cygwin Bugs (Read 162 times)
Rahul
Guest
Sep 14th, 2004, 11:29am
Hi All.
I am trying to compile spice3f5sfix on linux/cygwin.
After fixing many things in the make files I get one very wierd error in the string.c and misc.h files
In function `bcopy':
09: error: argument `from' doesn't match prototype
Has anyone fixed this problem ?
Rahul
  IP Logged
Rahul
Guest
Re: Spice3f5 on Linux/cygwin Bugs
Reply #1 - Sep 16th, 2004, 11:10pm
Pardon me for taking the Forum's time and bandwidth,
The bug is a cygwin problem and not linux. I was able to compile it on linux.
-Rahul
  IP Logged
tcad
Guest
Reply #2 - Aug 27th, 2005, 10:01pm
Do you still have problem to compile spice on cygwin?
This is neither a linux problem nor cygwin. You need to make some change accordingly in conf and os_port.h.
I can compile on both linux and cygwin system.
Min
  IP Logged
antonios
Guest
Reply #3 - Oct 4th, 2005, 8:48am
hello,
i am trying to install spice3f5 in linux
i still have some problems but i ws told that if i install the termcap libraries it will work.
my question is:
what things i willl have to change in order to install spice3f5 in cygwin?
thank you in advance
be well
antonios
  IP Logged
