Read the AMS Designer tutorial in the cdsdoc documentation. It explains about the need for connect modules - you've probably not compiled an appropriate connect module and connect rules, or not told it which connect rules to use.
Rather than me repeating the docs, look at <instdir>/doc/amsenvug/amsenvug.pdf (I think it is chapter 2?)
