Jul 21st, 2024, 7:28am
Error in Spectre when running process corner (Read 2227 times)
froggy
Nov 24th, 2004, 12:46am
I am currently doing post layout extraction simulation on Spectre. I am using Columbus RF tool for my layout extraction and Spectre to run my simulation. After post layout extraction, I am facing problem at Spectre when I changed alway the process corner to negative sigma. It will indicated the following messages:
" Error found by spectre in 'pfet': '+19' duirng hierachy flattening. I0.+19.djdb_area of pfet: Value of 'area' should be greater than or equal to zero"
I have try running the simulation at 0 sigma process corner and +3 sigma process corner, the simulation is able to run but I always face the above problem when I switch to -3 sigma corner. What causes this problem? Can anyone help me to solve this issue? Thank you
Mighty Mouse
Here I come to save
the day!
Fantasyland
Re: Error in Spectre when running process corner
Reply #1 - Nov 24th, 2004, 8:20am
It appears the '+19' is an instance of a subcircuit that contains a pfet 'djdb_area'. I believe that you will find that when running the negative corner one or more of the parameters of the '+19' model are being processed with the result being a negative number, and that number is being passed to the area of 'djdb_area'.
- MM -
