Are you saying that you're using ocnPrint() during a running simulation? If so, that won't work.
Some parts of ADE will work by doing this (for example, the plot outputs button), because they tell spectre to pause, flush its outputs, read the results, and then tell the simulator to continue. Other methods (like ocnPrint) will just read the data at that time - and will then probably not realise that it has changed when you do ocnPrint again.
Without more details of precisely what you're doing, it's hard to say...
