Jul 15th, 2024, 11:46pm
Average Power Vs. RMS power (Read 9168 times)
crhu
I come, I see, and I
go
Dec 22nd, 2004, 11:11pm
Hi, forum,
I am wondering what is the criteria to use average power
or RMS power in power simulation.
Acordingt to Poynting's theorem, Sav=Re(EXH), average
power should be enough for power measurement all the  EM field.
However, I find that there are many places, esp. in RF ckt, RMS power
is used instead.
Any inputs are highly appreciated.
Thanks.
--crhu
Re: Average Power Vs. RMS power
Reply #1 - Dec 27th, 2004, 1:13pm
Charlie,
Average and RMS power are the same, are they not?
The equation you gave for Poynting's theorem assumed the use of phasors, which assumes sinusoidal signals. When using RMS you are allowing signals other than sinusoids to be used.
crhu
go
Reply #2 - Dec 27th, 2004, 5:58pm
Hi, forum,
I googled "RMS average power" and here is something
giving me some hints:
http://www.dartmouth.edu/~sullivan/techniques.pdf
"More generally only components of v(t) and i(t) at
the same frequency contribute to average power"
If it is true ( I do not know how to derive it yet),
average power can not characterize the power for
non-linear circuit.  Am I right?
Thanks.
--Charlie
crhu
go
Reply #3 - Dec 28th, 2004, 2:02pm
Hi, Ken,
I went through the Poyting's Therom one more time, and
you are right  that the Saverage = Re(SXconjugate(H)) is
in the format of phasor.  As any periodic inputs can be decomposed into sinusoids of different frequency, the
Therom should be able to apply to all the periodic/quasi-
periodic inputs.
I do think right now that there is a hidden assumption in
Poynting's Therom: the changing E field only generates
the M field with the same frequency; so does the changing
M field, as the linear, homogeous medium is assumed.
So, seems to me that the average power is not a good
enough measurement for a non-linear system.
Thanks.
--Charlie
