Amorn
BKK, Thailand
Dear Kailun,
Select the extrapolated point within the +3dB/dB slope area of your IM3 curve (the same slope as 3dB/dB guide line), normally it is in the low power area. Choosing any point within this area will result in similar IP3.
Otherwise, using PAC analysis as describe in "Accurate and rapid measurement of IP2 and IP3" could help.
Regards, Amorn
