Jul 19th, 2024, 8:39am
IP3:How to choose extrapolation point? (Read 3171 times)
chingkailun
Malaysia
Dec 25th, 2004, 7:08am
Dear all,
I am designing 40MHz Gm-C bandpass filter(0.18u tech) using Cadence Spectra.
I have problem in choosing value for Input Power Extrapolation Point (dBm) when plotting IP3? I get different value for IP3 with different Input Power Extrapolation Point value. What does it mean? I am doing PSS analysis.
How do I know which value of IP3 that is correct?
Is there any rule of thumb?
Plz help..I am new to Cadence...
Thanks!
Kailun
View Profile 146408118   IP Logged
Amorn
BKK, Thailand
Re: IP3:How to choose extrapolation point?
Reply #1 - Feb 22nd, 2005, 12:46pm
Dear Kailun,
Select the extrapolated point within the +3dB/dB slope area of your IM3 curve (the same slope as 3dB/dB guide line), normally it is in the low power area. Choosing any point within this area will result in similar IP3.
Otherwise, using PAC analysis as describe in "Accurate and rapid measurement of IP2 and IP3" could help.
Amorn
