Sep 19th, 2026, 8:03pm
Cadence spiral inductor modeler (Read 16846 times)
gogomi
Jan 12th, 2005, 12:14pm
Have anyone used spiral inductor modeler in cadence?
I don't know why I always get a core dupmed when I
try to generate a model.
I don't know if it's possible if I generate the inductor
model from other tools such as ADS and run it in spectrel.
Thanks!
gogomickey
bernd
Munich/Germany
Re: Cadence spiral inductor modeler
Reply #1 - Nov 15th, 2005, 1:41am
It is.
I'm not very experienced with ADS but I think ADS
can write out a simplified Spectre Subcircuit of the
Inductor which is nothing else what the
Cadence Inductor Modeller does.
If not at least you should get a simplified Spice Subcircuit
form ADS which you can easily direct draw as a Cadence
Composer Schematic.
Bernd
Just another lonesome cad guy
Reply #2 - Jan 2nd, 2006, 5:50pm
Gogomickey,
  In IC5141 USR3 and MMSIM USR2, spiral inductor modeling
has been updated.  The new tool, Virtuoso Passive Component
Modeler provides a more comprehensive solution. It includes
support for PDK Development, Inductor Modeling, Inductor
Synthesis, and Verification.
337see733
Singapore
Reply #3 - Jan 16th, 2006, 6:42pm
There is a excel sheet to extract the model of the spiral inductor posted http://www.circuitsage.com/inductor.html. If you find it interesting, newer version has been developed. Can PM me to get it!  ;D
View Profile gilbertsee   IP Logged
Reply #4 - Aug 15th, 2006, 8:37pm
You can also develop a model with a chunk of university freeware: ASITIC
This is from UC Berkley and will get you a first order model.
http://rfic.eecs.berkeley.edu/~niknejad/asitic.html
There are other tools that will get you to a lumped element model which can be dumped back into Spectre -SPice - Eldo (pick one)
That includes: Sonnet, AnSoft and others have tools. Google "electromagnetic model" and you will find the players.
Jerry
waver411
Reply #5 - Jul 11th, 2007, 10:28pm
I need a TSMC 0.18 PDK for ADS,I want to ansys my sprial inductor model!
ayowchen
Reply #6 - Aug 5th, 2007, 6:11am
Is it possible to use Cadence VPCM to generate stacked parallel inductors incl. single-end, differential, and balun?
If yes, what about the accuracy? Is that product-proven?
andrewli
San Jose
Reply #7 - Aug 6th, 2007, 9:22am
Yes, it is possible. Use consecutive metall layers as winding, and the metal layer next to those winding layer as bridge, you can get stacked parallel inductors.
Regarding accuracy, please refer to the following press release:
http://www.cdnusers.org/InterviewwithEpochMicroelectronics/tabid/398/Default.asp...
Hope it helps
Andrew
ayowchen wrote on Aug 5th, 2007, 6:11am:
