Aug 16th, 2024, 5:27pm
Generic parameter passing in a record (Read 1927 times)
nicolas
Dresden, Germany
Jan 28th, 2005, 11:39am
Hello !
I have the following problem, I hope some can help me.
I've written an entity with a lot of parameters, so I decided to put them all in a type record in a package together with a constant declaration of this same type, where all default values are given:
package pck is
 type param_rec is record
   p1 : real;
   p2 : real;
 end record param_rec;
 constant default_params : param_rec :=
 ( p1 => 1.0, p2 => 2.0, ...);
end package pck;
So the bottom level entity is initialized with the default
parameter values:
entity bottom_entity is
 generic( param : param_rec := default_params );
 port( ... );
end entity bottom_entity;
In the upper level entity I would like to redeclare
only a couple of parameters, not all of them:
E1 : entity bottom_entity ( my_struct )
    generic map( param.p1 => 2.0 )
    port map ( ... );
Here the compiler issues the error: "too few values for
record aggregate". I thought one could reassign individual
fields of a record without the need to reassign all of them,
particularly because the other fields should have their default values. Does someone know a better solution or see an error above?
Nicolas.
