qadeer
Yawei,
Even if the device is able to handle vds of 10V, there is a limitation on vgs, vgd and vgb due to oxide breakdown, I would recommend you to check the design rule manual for the process. If the devices are not able to support, the there are techniques like cascoding the devices to limit the vds and run your circuit at higher supply.
Regards, Qadeer
