Aug 15th, 2024, 1:52pm
The maximum supply voltage for a 0.6um CMOS? (Read 6877 times)
Feb 07th, 2005, 7:26am
I am designing a voltage detector IC using 0.6um CMOS technology, which requires the supply voltage as high as >10V.
Pls give me any advises or references about power IC.
Is it possible to make a circuit with supply voltage > 10V?
Yawei
FragMent
Guest
Re: The maximum supply voltage for a 0.6um CMOS?
Reply #1 - Jul 7th, 2005, 2:41am
Thare are some IC foundry that provide high voltage 0.6u CMOS process. For example XFab in Germany
  IP Logged
Reply #2 - Jul 7th, 2005, 3:04am
YW,
  Also see the PolarFab page. They have a 0.5um process that supports
up to 40V. Are you trying to design a 10V power IC on a stnadard
CMOS process? Or has the process been enhanced for high voltage
applications? For example, does the process have thick gate oxide
for high voltage transistors? Is there an LDMOS or DEMOS device
available? The line width may not be as important as the structure
of the devices available.
kwkam
Earth
Reply #3 - Jul 7th, 2005, 5:24am
You can check the Vds break down voltage from the EDR of the procoess. Usually, 0.6um CMOS process can handle ~10V Vds break down
qadeer
Reply #4 - Jul 12th, 2005, 9:13am
Yawei,
Even if the device is able to handle vds of 10V, there is a limitation on vgs, vgd and vgb due to oxide breakdown, I would recommend you to check the design rule manual for the process.
If the devices are not able to support, the there are techniques like cascoding the devices to limit the vds and run your circuit at higher supply.
Qadeer
