Nov 7th, 2026, 9:28pm
Up-Down Counter (Read 2427 times)
jr81
Up-Down Counter
Feb 18th, 2005, 5:24am
Hi all I am trying to implement an automatic up/down counter. I have come up with the following code. It simulates fine but when I try to synthesis it the output just toggles between "0000" and "0001". Any suggestions on how to improve it.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
--  Uncomment the following lines to use the declarations that are
--  provided for instantiating Xilinx primitive components.
--library UNISIM;
--use UNISIM.VComponents.all;
entity waves is
    PORT(
           reset,clk      :in std_logic;
           wave           Shockedut std_logic_vector (3 downto 0);
           serialout : out std_logic
end waves;
architecture Behavioral of waves is
signal count_wire   : std_logic_vector (3 downto 0);
signal e1                : std_logic;
signal shift             : std_logic_vector (3 downto 0);
begin
count_proc:   PROCESS(clk,e1,reset)
BEGIN
    IF (reset = '1') THEN
     count_wire <= "0000";
     ELSIF (clk'EVENT AND clk = '1')THEN
                    IF e1 = '1' THEN
                count_wire <= count_wire + 1;
                else
                count_wire <= count_wire - 1;
     END IF;
      END IF;
END PROCESS;
wave <= count_wire;
e1 <= '1' when count_wire = "0000" else
          '0' when count_wire = "0111" else
          e1;
END;
