Jul 19th, 2024, 12:34am
Input file for vpwlf source (Read 523 times)
kamesh419
Feb 18th, 2005, 6:54am
Dear all,
    I came to know that vpwlf source in cadence can take its input from a file and convert it to pwl sources. I need to know how the "input file" should look like for the vpwlf source (I have information like at what time i pass what digital inputs to my 8-bit adder). an example file will be better. Then i can use TCl to generate such a file.
If you can give me the logic behind generating this file then that will be great.  :)
Thanks in advance
kamesh.
« Last Edit: Feb 18th, 2005, 8:40am by kamesh419 »
Truth lies everywhere and partially even with the error.
Re: Input file for vpwlf source
Reply #1 - Feb 18th, 2005, 9:04am
From "spectre -h vsource":
Quote:
A vector of time-value pairs describes the piecewise linear waveform. As an
alternative, you can read the waveform from a file. In this case, you give time-
value pairs one pair per line with a space or tab between the time and the
value.
