Jul 23rd, 2024, 6:20am
how to plot gm/I0 and fT/I0 in analog artist (Read 5072 times)
nus_lin
Mar 18th, 2005, 8:02am
Dear guys,
I am using cadence, analog artist. the simulator i use is spectre. Now i need to sweep I0 and plot the change of transconductance and other parameters as the position of poles. can anybody told me how to do that?
there is an option like "setup output" from the pop-up window of simulator, is is the correct access to the parameters like gm, cgs,cgd?
Re: how to plot gm/I0 and fT/I0 in analog artist
Reply #1 - Mar 20th, 2005, 2:35am
This has come up a few times. A quick search (using the search button at the top of the Forum), for "gm sweep", setting the maximum post age to 600 days,
gave this (amongst others):
http://www.designers-guide.org/Forum/?board=circuit;action=display;num=107949162...
nus_lin
Reply #2 - Mar 20th, 2005, 10:57pm
Many thanks  to you, andrew. but can you tell me more detail about where to put the include file? is there any old include file for spectre simulator? i cann't find any include file in my working directary,   Embarrassed.
Reply #3 - Mar 20th, 2005, 11:09pm
If you're using the analog design environment, choose Setup->Model Libraries, and then add the included file there. You can put it wherever you want, if you give the path to the file. Or you can set an include path (on the Setup->Simulation Files form) and then give a relative path on the model libraries form.
smchiu
Reply #4 - Jul 23rd, 2006, 1:34am
Hi Andrew,
May I by the way ask a similar question on this?
I want to plot gm/I vs Vgs-Vt instead of just vs Vgs. In Hspice, I use to use a command called .probe with PAR to set Vgs - Vt to a certain single variable to plot it. However, in SPECTRE, I am not sure what to do. Please advice.
Thanks a lot.
David.
ADDA
Reply #5 - Jul 24th, 2006, 6:19am
You can use caculator to get what you want.
smchiu wrote on Jul 23rd, 2006, 1:34am:
Hi Andrew,
Thanks a lot.
David.
