jimmy li
Guest
I just started to try using Ultrasim. I have a question here.
After I started the transient simulation, it doesn't show the progress in a continous way, but in a "discrete timeway". I mean, it only tells you that it has finished "10%", then "20%", and so on. I can only reload the signal waveform in a similar "discrete-time" way.
I am wondering if I can see the progress and update the waveform in a simiar way of Spectre simulator. That will give me a better idea of the simulation progress and simulation result.
thank you for your help.
jimmy li
