Aug 22nd, 2024, 2:24pm
question about ultrasim (Read 561 times)
jimmy li
Guest
Mar 27th, 2005, 4:59pm
I just started to try using Ultrasim. I have a question here.
After I started the transient simulation, it doesn't show the progress in a continous way, but in a "discrete timeway". I mean, it only tells you that it has finished "10%", then "20%", and so on. I can only reload the signal waveform in a similar "discrete-time" way.
I am wondering if I can see the progress and update the waveform in a simiar way of Spectre simulator. That will give me a better idea of the simulation progress and simulation result.
thank you for your help.
jimmy li
  IP Logged
Baolin Yang
Guest
Re: question about ultrasim
Reply #1 - Apr 19th, 2005, 3:59pm
Hi Jimmy,
In my experience, the waveform will be updated more "continuously" after the first 10%.
Also you can use Ultrasim option
.usim_opt progress_p=1
to update every 1% instead of 10%.
Baolin
  IP Logged
