Paul
I agree with Raymond's point that XL almost makes LVS unnecessary. But notice that the connectivity verification running in the background requires some CPU power. Personnally I would discourage you from running VXL from beginning to the end of the layout task without having an up-to-date machine. E.g., it works correctly on a Sun Ultra 10 (400MHz, 1GB RAM), but I consider that machine as being the lower bound of the range. I agree, that machine is not so recent... No experience on Linux.
One more remark: if you have a repetitive design (this was my case), it was faster to give up XL and do copy-paste, losing the connectivity information, than redrawing the repeated parts several times with connectivity info.
As a final statement, VXL is definitively the future in layout, but you must be aware of the current limitations (CPU, no support of copy-paste, little device matching operations). Finally, check with your layout designers, it may take some time to convince them to change their working style.
Paul
