microant
China,SH
hi james maybe you can change 'tr' instead of 'vctr', in Hspice when use DC/AC/TRAN analysis, the sweep param is not better with the first letter such as 'V', 'I', the hspice will recogenize as a independent voltage or current source.i have meet with the similar problem. you can try it:) best regards microant
