Oct 3rd, 2026, 4:49pm
memeoty leak problem of icfb 5.1.41 (Read 2555 times)
jimmy
Apr 22nd, 2005, 10:49am
I am runing icfb 5.1.41 on our linux machine. Whenever I run cadence, there are a lot processes generated and the memeory is taken more and more. Even though I quit cadence, most of the memory are still taken. As the result, the speed of the machine becomes very slow. When I run old version cadence (cifb5.0), there is no such problem. I don't know how to solve this problem.
The linux op I am using is Red Hat Enterprise Linux WS release 3 (Taroon Update 2)
Hope someone can kindly suggest me a solution.
thanks a lot,
jimmy
Re: memeoty leak problem of icfb 5.1.41
Reply #1 - Apr 22nd, 2005, 9:52pm
Well, if it was really leaking memory after the program has exited, that would be an OS problem, not the fault of the tool. The OS is responsible for managing the memory heap - and when a program exits, the OS gets the memory back - and so if it is not allowing it to be re-used, the OS is at fault.
However, be wary that "top" does not necessarily tell you the amount of free memory - Linux uses that memory for other things (file caching, I think, if I remember rightly), and so it doesn't show up in the "free" memory in top - but as soon as another application comes along and needs it, it should be available to that application. That's the idea anyway...
The other alternative is that there is still some process running which is hogging the memory. We often get people pointing out all the many java processes running - but these are a consequence of the way that java threads are implemented on Linux - as separate processes using shared memory.
