Strangely I'd never noticed the Command Type In form before. From hitting the help button on this form, and from experimenting with it, it allows you to enter cdsSpice commands - which allows you to control cdsSpice (which is what is responsible for preparing the final netlist and controlling the hspice simulation under hspiceS). You cannot enter hspice netlist statements in this window.
To add an hspice syntax include file, use Setup->Environment, and enter a path to an include file. Make sure you set the include/Stimulus file syntax to hspice rather than cdsSpice on the form.
If you were using the newer hspiceD interface (hspiceS is obsolete), then you could add the include file by Setup->Model Libraries, or by using the definition file under Setup->Simulation Files.
