Aug 18th, 2024, 6:17am
minr in Spectre (Read 3605 times)
Sid
minr in Spectre
Jun 27th, 2005, 11:17am
I have very large MOSFETs in my DC-DC converter circuit. This results in the MOSFETs having a resistance less than 50 milli ohms. Now, Spectre does not consider these resistances since they are less than minr value. But I want it to simulate WITH these resistances included.
How do I change the minr parameter?
Sid
Re: minr in Spectre
Reply #1 - Jun 30th, 2005, 5:24am
I believe you may have to set "minr=1e-3" in the model card for the large device(s).  This could be a nuisance if you have lots of model cards.  There is a simulator option
simOptions options minr=1e-3
but I think the local one (in the model card, which has a larger default) is applied first, without checking the global value.
Re: minr in Spectre
Reply #2 - Jun 30th, 2005, 7:51am
Using small values for parasitic resistors can cause convergence problems. If this occurs, you will need to loosen iabstol.
