spiceoracle
USA
Plotting OIP3 and IIP3 using HSPICE is not possible.
HSPICE will not show non-linear effects such as compression points or intercept points. If you want to simulate non-linear effects, you will need to use HSPICE RF. You can then measure OIP3 and IIP3 using CosmosScope.
