Jul 24th, 2024, 6:18am
Accessing temperature in Spectre (Read 5663 times)
vivkr
Jul 25th, 2005, 2:12am
I am trying to use some environment variables in computing the outputs that I obtain for a large batch of runs. I am unable to find the option which would allow me to automatically find the temperature for which I simulate my circuit. Of course, I can see it but in running Corner Analysis with about a 100 odd corners, it would be useful if I could get the information using the Calculator.
Any suggestions are welcome.
Vivek
Re: Accessing temperature in Spectre
Reply #1 - Jul 26th, 2005, 3:51am
Not quite sure why this is in the AMS section of the forum, but since it is, here's a possible solution.  Use the Verilog-A module below, and connect its output to a node; the voltage of that node will then be the temperature of the circuit (in Kelvin), and thus you should be able to get access to it in the Calculator.
`include "disciplines.vams" // or "discipline.h"
module tempout(out);
 inout out;
 electrical out;
analog
  V(out) <+ $temperature;
Reply #2 - Jul 26th, 2005, 8:08am
In general it is a bad idea to use electrical nodes to pass non-electrical quantities. It tends to mess up the tolerancing. I recommend you use the thermal discipline for the output node.
Reply #3 - Jul 31st, 2005, 9:39pm
Going back to the original question, which was how to access the simulation temperature in the calculator, it would be (something like):
resultParam("temp" ?result 'tran)
Note, the 'tran would be whatever analysis you're running and want to get the temperature from.
