Feb 10th, 2026, 9:06am
How to find a point value using expression?? (Read 4043 times)
littlepig
Guest
Aug 19th, 2005, 1:23am
Is there any possible ways to find out y-value at a particular x-value by using some expression???
(Waveform is volage vs time)
Thanks...
  IP Logged
Jess Chen
California Bay Area
Re: How to find a point value using expression??
Reply #1 - Aug 19th, 2005, 8:01am
What tools are you using? Many user interfaces have waveform calculators that do the job. If you are using Spectre and do not have a GUI, you can do the job with VerilogA or SpectreHDL and probably the fairly new MDL(measurement description language?).
If all you have is raw UC Berkeley SPICE, your options will be more limited.
Scott Flinchbaugh
Reply #2 - Aug 24th, 2005, 6:32pm
If you have access to spectremdl, construct the following
MDL file.
alias measurement foo
    run tran( stop=<stoptime>)
    export real yval = V(<signal>)@<xval>
run foo
------- end of file
In this measurement
<stoptime> = transient analysis stop time
<signal> = node name of interest
<xval> = time value of interest
Hope this helps.
View Profile flinchba   IP Logged
Reply #3 - Aug 27th, 2005, 12:31am
If you're using the ADE calculator (either the old one, or wavescan integrated in ADE), or OCEAN, you would use:
value(v("/signal") 0.5u)
for example.
