Aug 16th, 2024, 1:13am
C/N of Low-IF Receiver with small Gain (Read 168 times)
Sep 05th, 2005, 8:40am
Hi.
How do you measure C/N or NF of Low-IF Reciever which doesn't have much Gain ?   Kiss
Generally Noise Source for NF Meter is valid from 10MHz.
I can't evaluate C/N reliably using Spectrum Analyzer since
Receiver doesn't have much Gain.
Is there any practical or reliable instrument in commercial ?
Noise/Com Inc. has good solution ?
http://www.noisecom.com/
cybq
Re: C/N of Low-IF Receiver with small Gain
Reply #1 - Jun 8th, 2006, 11:24pm
try to use enough low noise floor spectrum analyzer, with addition of RF probe (it is a hign input impedance device).
keplin
SF Bay Area
Reply #2 - Aug 5th, 2006, 11:38am
How about using a really low resolution bandwidth on the Spectrum Analayzer and using a Noise Source with an ENR of say 15dB?
This should work well.
View Profile keplin keplinjohansen   IP Logged
