sugar
I am doing corner simulation with spectre by using ocean script. My simulaltion bench includes a Verilog-A module used to measure jitter of the output signal. For some corners, simulation can be successfully done, but some corners fail. The error message is, Internal error found in spectre during initial setup. Please run 'getSpectreFiles' or send the netlist, the spectre log file, the behavioral model files, and any other information that can help identify the problem to support@cadence.com. Segmentation fault.
This error happens randomly. If I re-run the simulation, then the previously failed corners can be ok, but other corners might fail.
Help me, thanks!!!
